LarryJM
Dec 12, 2013Explorer II
donn0128 wrote:
Did you add the SPST mini switch? You need it in the system to make the AC fan work correctly. AC fan is normal high speed.
That is mostly wrong and misleading since as others have mentioned you only need the switch if you want to have and be able to select the =HI or LOW A/C fan speed.
Larry
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 24, 2026
