DeansDad
Dec 21, 2013Explorer
Update on my conversion:
Chris was correct - I had to have BOTH the blue & orange wires (fan wires) on G to make the cooling fan come on..... I haven't added the switch, as my dealer in Texas said the low speed would sometimes allow a freeze-up to occur.
I totally missed the switch wiring showing the switch adds the 2nd wire to the circuit.
Additionally I believe the pins were not making contact between the thermostat & mounting base properly - I remounted the base as I had an over-sized hole for one screw. After The solid mount it clicked together like it should have.
The only thing is that the A/C fan (not compressor) turns on when the heat is on (furnace fan also works then). But I guess it just circulates the heat better as there is no cooling, just air movement.
This mod keeps the A/C w/in 1 degree, and also seems to start the compressor better (no more short cycling and buzzing, just instant starts).
Thanks for the help!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,421 PostsLatest Activity: Sep 24, 2026
