tenbear
Jan 26, 2015Explorer
When I installed a voltmeter I used a SPDT switch to switch the meter to read either the battery voltage or the converter voltage. The switch has a center off position.
For the converter voltage I chose to tap into the wire to the propane detector. It draws a constant low current and is on a fuse with nothing else. For the battery voltage I went directly to the battery.
There is definitely a difference between the two, especially when the converter is in boost mode and the battery is low.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
