tenbear
Jan 27, 2015Explorer
audio1der wrote:
Momentary switch is what I would do as well. Then you have draw only when you want to check the voltage and minimize your parasitic draw.
Alternatively, a battery disconnect switch may not be a bad idea for when in storage or between trips.
I originally had a momentary switch on my voltmeter but I replaced it. I didn't like holding the switch on when I wanted to watch the meter.
The parasitic drain of the meter is very low. If you don't want to watch the meter, just turn it off.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
