crcr
Jan 27, 2015Explorer
ewarnerusa wrote:
Looks good crcr. What is a Radio Shack hobby box? I may walk over to RS at lunch and check that out if it means fewer/smaller holes cut into my TT interior paneling.
I don't recall if that was what the label on the plastic work box said, but that is what the Radio Shack clerk called it. They had 2 or 3 sizes. It's a nifty plastic box with removable top, held by 4 screws. Using a dremel tool, I cut out the correct size square hole in the box cover to mount my LED volt meter from Amazon into it. Then drilled a tiny hole in the back of the box to bring the pos and neg leads in to connect to the volt meter. Then just a couple of tiny screws inside the box to mount it to the underside of the cabinet.
Whenever I sell the trailer, I'll probably remove it and install in the replacement trailer. That would leave no visible trace it had been there.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
