tenbear
Jan 27, 2015Explorer
64thunderbolt wrote:tenbear wrote:audio1der wrote:
Momentary switch is what I would do as well. Then you have draw only when you want to check the voltage and minimize your parasitic draw.
Alternatively, a battery disconnect switch may not be a bad idea for when in storage or between trips.
I originally had a momentary switch on my voltmeter but I replaced it. I didn't like holding the switch on when I wanted to watch the meter.
The parasitic drain of the meter is very low. If you don't want to watch the meter, just turn it off.
I don't need to monitor it more than 2 times a day so why look at it?
Whatever fits your needs.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
