ewarnerusa
Jan 28, 2015Nomad
Fixed Sight Training wrote:
I used a voltmeter that just plugged into the 12 v cigarette lighter. It was pretty accurate when checked with my multi meter. No drilling or wiring and I can pull it out and check other RVs or cars with it.
I have one of those and I also like it. I have decided to go down a different route for a couple reasons. (1) I already have this voltmeter that has been sitting in the tool box for a year or so and I'm motivated to install it. I think it will be more "pro" looking. (2) The 12V outlet that I've used for the plug-in voltmeter is on the same circuit as the propane detector and radio. This winter I decided to pull that fuse to reduce the parasitic draws while the TT is parked in the driveway for the winter. I have found that when my solar panels get buried under the snow, my battery voltage starts to fall behind after a few days and I'll have to plug the TT in and let the converter charge them back up to 100%. This winter I pulled that fuse and notice an improvement in maintaining battery voltage during this scenario. But to check the voltage I have that plug in meter in a different 12V outlet that is less convenient to check. It is in my pass-through storage area where my solar controller and inverter are installed. So this motivated me to come up with something better and leads back to my reason (1)! :)
As an update, I wired up the voltmeter last night to verify that I get a good 12V reading. I picked some "favorite" wire nut junctions that I confirmed with my multimeter will give me an always-hot 12V reading and wired the voltmeter directly to them. I was initially disappointed because the voltmeter consistently read 0.2V lower than what my multimeter read. My other plug-in voltmeter at the other location confirmed the multimeter reading. I went back to the amazon listing for the voltmeter and read in the reviews that the reading can be calibrated by turning a potentiometer on the rear of the unit. I confirmed that this is the case and I adjusted to voltage reading so it was the same as the multimeter reading. I'll update again when the project is finished.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
