teddyu
Jan 31, 2015Explorer
I installed a self-powered voltmeter (under $5) that monitors the auxiliary (coach) battery buss. Itβs mounted in the dashboard above the Generator run-hour meter and is connected to an auxiliary (coach) battery terminal on the BCC battery isolator solenoid through a 1A fuse. This allows for continuous monitoring while driving.
By monitoring the auxiliary battery buss:
One, with the engine and shore power/generator OFF β I know the charge condition of the coach batteries. Two, with the engine ON β I know the charge condition of the coach/chassis batteries, the functionally of the BIRD, and the output of the engine alternator. And three, with shore power/generator ON β I know the charge condition of the coach/chassis batteries, functionally of the BIRD, and output of power converter.
I bought (from Jennyear on eBay) a self-powered Green 3~30V (12V) Mini Digital DC LED Battery Voltmeter and bezels (items 130875885643 & 140940500425).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
