down_home
Sep 19, 2013Explorer II
Replace the pump with Aqua Flow or one of the others with specs you like.
Ours came with an Aqua Flow, pump. It is 3.5 gal at 55 psi per literature with coach. It was replaced once, I think and not sure it is the same but it puts out more pressure than many or most campgrounds.
I like it at 60lbs or better at home. Afraid to do any mods to boost it in the coach as many express concern with the flexible piping used in them.
We've seen pressures of 80 lbs at a couple of campgrounds in Ky with no problems though.
We intend to use pressure regulator but one we have was belly up from the get go and to cheap to replace it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
