trailernovice's avatar
Mar 03, 2013
ideas re. best way to transport motorcycle
We would appreciate advice re. best way to transport a motorcycle...it's fairly small, with a full-up weight of just under 600 pounds...
options we've considered...
1.) back of pickup...downside is the loading and unloading scares me to pieces--several hundred pounds, up and down a skinny, steep ramp...nightmares about the thing going over the side of the ramp, with possibly me underneath it...upside is minimal expense and nothing to buy or deal with other than a ramp
2.) get or have constructed a small utility trailer and double-tow behind the TT...upside is low ramp and basically no engineering concerns...downside is it would be a hassle because the motorcycle would have to come off the trailer and then the trailer would have to be unhooked and hand-pushed out of the way before backing the RV rig into a site..other downside would be need to have a hitch welded to the trailer frame and get the TT wiring jiggered such that it could run the lights on the double-tow
3.) have a small platform welded to the TT frame...would allow the motorcycle to be loaded from the side of the trailer...upside is compact, out of the way and pretty much hassle free....downside is, if not done right, the thing breaks loose, dumping the bike and endangering everyone following us
A small toy hauler would be ideal, but that's not in the cards for the time being...
Would appreciate input, especially from those who have faced and solved this issue...
thanks!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
