JiminDenver
Jun 04, 2013Explorer II
The tubing used as duct work is creating a huge amount of turbulence and slowing the air flow down. That in turn can cause the fan to not move enough air allowing the furnace to get too hot and the burner to shut down until the fan reduces the heat level.
Helper fans at the end of the ducts may help but replacing with a smooth walled duct would do the best.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
