Hudsoner's avatar
Hudsoner
Installed ceiling fan
I installed a 12V ceiling fan into the bedroom. My bedroom is wired for an air conditioning unit, but I did not want this because of the noise those things are making. I get OK cool air through the ceiling ducts, and just wanted some extra air movement.
I decided to install the fan in the center over the bed, by utilizing the metal support of the opening there. I modified a fan support outlet that is used for stick houses and painted this thing white. I made cutouts in the skylight surround to install the fan box. I ran the wires through the ceiling to the 12 V lights, and from there to a surface mounted on/off switch.
This fan provides some well appreciated extra comfort, it is very quiet and can run the entire night. This way I have some "fresh" air even if the generator is not running. I installed the fan in such a manner that it still allows me to crank the hatch open.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
