gaymeadowsman's avatar
May 31, 2017
Installed the Maxxair fan, odd find
This past weekend we picked up the MaxxAir fan, simple 4 seed manual open,to replace the stock single speed fan in our Avenger travel trailer bathroom. With the vent cover over it that little fan barely pulled the steam from the shower out of the room much less drew any air through the trailer.
Anyway, Removal was as I expected except, when I lifted the fan from the roof,there was no Butyl tape. It had the same caulk that was on the top side covering the screws and flange. I don't guess it is anything "wrong" with it,but of all the videos and how to's I had read they all had butyl tape under the factory install. It did make for a longer prep for the new install.
Is this another example of Prime Time cutting corners? I've found a few...
Now I just have to adapt my perfectly good Camco cover to the new fan. MaxxAir fans are now made to only use redesigned MaxxAir covers.
  • sgip2000 wrote:
    Bumpyroad wrote:
    I think he is talking about the little whirr and buzz being inadequate, not the new one.
    a reminder, do not have the bathroom door closed, the fan on max and flush the toilet.
    bumpy
    Are you speaking from experience?
    A lot of us speak from the same unfortunate experience. :(
  • The lap sealant, did not leak rain, did it ?
    And it did not dry out
    And I bet it cost more money than the butyl putty tape
    I would Not call that cutting corners
    The cheap little fan, was cost cutter
    Yous gots da point!
    And point taken. :S
  • drsteve wrote:
    Dusty R wrote:
    Speaking of MaxxAir. I would like to find a MaxxFan 1200T.
    I put one on our 2003 mh. In 2015 we bought a new mh, and when I tried to get another 1200T, I found that that model is no longer made. We liked that model so well that we want another.
    Dusty
    http://rvpartaccessories.com/products-page/rv-electrical-wiring/vent-cover-turbo-maxx-model-1200t-wthermostat-00-965001-by-maxxair/
    I found them, but they appear to be out of business. They did not respond when I tried to order one from them.
    Thanks,
    Dusty
  • rhagfo's avatar
    rhagfo
    Explorer III
    mike-s wrote:
    You're lucky. A lot of the sealants cure to be almost unremoveable, making it near impossible to remove whatever without damaging the roof. Good quality butyl tape (Dicor makes that, too) under, sealant on top. That way you can carefully cut through the sealant around the edges and easily remove whatever since the butyl won't act like a strong adhesive. That applies double for things with wide flanges, like the base for an antenna.
    Why do you feel the need for the butyl tape if it didn't leak with the old vent? When I replaced the vent in our kitchen just lap sealant, easy removal, went back in the same way, dry to roof, then careful application of self leveling Dicor sealant.
    Whoosh. The GP described sealant under the fitting, "It had the same caulk that was on the top side." I commented that in comparison, using butyl tape is the proper method, since it doesn't glue the fitting to the roof.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
