SoundGuy
Nov 02, 2015Explorer
RoyB wrote:
My GRAY tanks on my POPUP is two 7.5 gal aqua-tainers totes. When one fills up I swap the drain hose to the other other one...
There's no need to swap out a full 7 gal Aquatainer with an empty one ... just interconnect them as I used to do with our Santa Fe, when the first fills to capacity grey water will automatically begin filling the second - guaranteed. :B
As for adding a grey water holding tank to a popup I can't think of a more pointless exercise as that grey water is going to have to be offloaded anyway when the tank fills to capacity, which it will in no time at all ... heck, I use the same grey water Aquatainers I used years ago with our Santa Fe to off load grey water from our travel trailer's 30 gal GW holding tank.
Regardless of what approach you take It's the same process - eventually that grey water is going to have to be off loaded into some sort of portable tank for disposal, be it a wheeled tote tank or a portable container like an Aquatainer which holds the advantage that it can still be picked up when full by the average person.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
