stasha
Mar 18, 2017Explorer
ScottG wrote:
The RV tubs I've seen have tall walls where the door is so support isn't an issue.
The bigger problem is having enough hot water to be able to put more than a few inches in the tub.
We have a tub but it's not really usable with our 6 gallon Wh.
If you do this please post some pics. I think a lot of use would enjoy seeing your progress!
Good points by you and TeachersPet -- the amount of water needed.
Yes, good idea to put in one of those instant hot water heaters -- takes juice though.
OR, could install a back up 10Gal propane h20 heater, huh.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
