BurbMan
Jan 27, 2021Explorer III
I guess it depends on your water use and the amount of room you have for installation. The one that Sure-Flo sells, which is what @deltabravo used in his video, holds about 1/2 gal.
The Watts I installed holds about 4.5 gallons, and was $10 cheaper than the "RV" version. I also had the room for it under the sink in the Terry TT, if I was going to put one in the Lance, I would only be able to fit the SureFlow under the sink.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
