awhiting80
Jul 18, 2015Explorer
Calicajun wrote:
You can't use the 12v plug for your inverter to power the TV and DVD. The reason is if you read the fine print (I read mine last night) it says using the 12v plug will only produce 100 watts of power. You will need to run 6 gauge wire directly from the battery to the inverter. Then you should be good to go.
I was using my inverter plugged into my 12v outlet in my pervious TT with no problems running the LED tv and DVD player.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
