deltabravo's avatar
May 20, 2021
Installing an Inverter
Last fall I installed an inverter in my rig.
It was a pretty involved process with a lot of prep and planning required because I had to relocate a few things, build a small platform for the inverter and also switch to a shorter range (stove / oven)
I broke the project up in to several videos, starting with showing tools I use for the battery cables and how I built them:
Temco TH0005 Hydraulic Crimper
Building the battery cables
Part 1: Project Planning
Part 2: Battery tray, shunt and fuse mounting
Part 3: AC and DC Wiring
Installing the new Range
Project completion: Color Control GX remote and BMV-712 Battery Monitor
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
