Dutch_12078
Aug 10, 2020Explorer III
I'm assuming the antenna base is not magnetic, so how will it be attached to the aluminum ground plane? The steel ground planes I installed have 3M double sided trim tape on the back, and the edges are sealed down with 2" wide EternaBond tape. One plate is at the front of our coach roof and the other is on the rear AC shroud.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
