nremtp143
Apr 24, 2016Explorer
ICamel wrote:
Most screen doors have a channel on the inside around the door areas. If you have a piece of Lexan cut to fit inside those channels the Lexan material has enough flex that you can fit it in. Then use some window screen vinyl spline rope to hold it in place.
That's what I did on both of my Sandpipers, but the door of my Montana is a little different and may have to try a different approach.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
