azrving
Jan 11, 2015Explorer
Double flare.
Propane hose like Mr Buddy or have it made at reputable shop.
It appears that you will tee the line, go through a shut off valve, then straight to the heater. I would also use the quick connect fitting. Put a protective cap on both ends when not using to keep crud out. Yes, I know how much they cost. :)
It appears that the heater is low pressure so it will run off your rv propane system. If you install another regulator it wont work.
The green wire is probably a ground wire. Do not remove.
Ride the wave
The worst thing that may happen is trying to run several appliances at one time. You may need to upgrade the regulator.
Ride the wave
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
