gkainz
Jan 19, 2015Explorer
djbroughton wrote:
I would like to install my new Olympian Wave 8 catalytic heater into my existing propane system. The best spot that I can see is under my main counter area (built into one of the slides). The attached photo of the line that services the propane range is where I am thinking of doing this. Also a photo of the heater connection. Questions:
1. can I plumb this using brass screw fittings as opposed to cutting copper line/flaring etc. as I am not experienced with this.
2. what kind of hose would I purchase to run to the heater?
3. the heater comes with a low pressure regulator. Am I right in assuming that gas to the stove is already low pressure and I won't need a regulator?
4. I don't suppose I can use the low pressure propane line supplied with the heater?
5. out of curiousity, what is green is the heavy guage green wire attached to the copper propane tubing?
I haven't totally decided on whether a quick connect is needed or if I will permanently mount the heater on the bottom of the counter unit.
Thanks for any advice.
Dave B
2006 Monaco Camelot 40PDQ
linked for you - you have to get the whole URL for the image ... when you click on the image, you'll see links to the right. Grab the Direct link and use the Image icon in the editor here.
Moderator edit to re-size picture to forum limit of 640px maximum width.
edit - oh yeah ... you have to make sure you stay at 640 width or less :) (add "width=640" in the img tag) if you quote this, you'll see the code.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
