GACamper
Jan 31, 2015Explorer
gkainz wrote:djbroughton wrote:
I would like to install my new Olympian Wave 8 catalytic heater into my existing propane system. The best spot that I can see is under my main counter area (built into one of the slides). The attached photo of the line that services the propane range is where I am thinking of doing this. Also a photo of the heater connection. Questions:
1. can I plumb this using brass screw fittings as opposed to cutting copper line/flaring etc. as I am not experienced with this.
2. what kind of hose would I purchase to run to the heater?
3. the heater comes with a low pressure regulator. Am I right in assuming that gas to the stove is already low pressure and I won't need a regulator?
4. I don't suppose I can use the low pressure propane line supplied with the heater?
5. out of curiousity, what is green is the heavy guage green wire attached to the copper propane tubing?
I haven't totally decided on whether a quick connect is needed or if I will permanently mount the heater on the bottom of the counter unit.
Thanks for any advice.
Dave B
2006 Monaco Camelot 40PDQModerator edit to re-size picture to forum limit of 640px maximum width.
Do Not use Quick Connect Fitting inside the camper. Your creating dangerous issue. Quick Connect are known to leak over time.
Looking at the picture, that is a 3/8 flare nut connected to the hose which has a 3/8 male flare fitting on it.
You can get a 3/8 flare tee and a 3/8 flare swivel to tie in at that connection. The 3/8 flare swivel will connect the hose to one end of the Flare Tee. The 3/8 flare nut on the copper line in the picture will connect to the other end of the flare tee.
You are correct that you do not need the Regulator that came with the heater. So you'll want to remove it. The gas system on the camper is Low Pressure.
What I can't see is how the hose is connected to the Regulator. Most of the time the hose has a Male Pipe Thread Fitting which could be a 1/4" or 3/8" Male pipe thread that screws into the Regulator. If that is case, you can get a 3/8 Male Flare X ? Female pipe thread to screw onto the fitting on the hose going to the heater. On this connection you will need to use a sealant such as pipe dope or Gas Thread Tape "Yellow".
Then you'll need another 3/8 Flare Swivel to connect the hose to the 3/8 flare tee.
Using these fitting listed will keep you from having to cut your gas lines. Also once done turn you gas one and check all connections for leaks.
Note: Use only Flare Fittings, do not use compression fittings.
Flare Fittings do not need sealant.
Make sure all fitting and hoses are LP Gas Rated.
The green wire is a ground wire from one of your appliances. That wire really needs to be move to a frame ground connection. Never understood why they would ground to a gas line. Last thing you need is s short to the gas line. They do the samething to mobile homes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
