Chris_Bryant
Jan 31, 2015Explorer II
GACamper wrote:
The green wire is a ground wire from one of your appliances. That wire really needs to be move to a frame ground connection. Never understood why they would ground to a gas line. Last thing you need is s short to the gas line. They do the samething to mobile homes.
That wire is required- it isn't a ground *too* the gas line, it's grounding the LP line itself- should be run from the line to the frame.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
