pianotuna
Jun 20, 2015Nomad III
Hi T/B.,
'This is a 240V/11KW/60Hz whole home water heater that is easy to install as it simply wires {requires 6 gauge AWG (American Wire Gauge) copper wire} into a 240V breaker (min required one 50 Amp breaker'
I repeat, you would need a second power source.
Tom/Barb wrote:pianotuna wrote:no, but you will be required to re-wire the 30 amp coach to a 50 amp coach.
Hi,
Would need a 50 amp service for the water heater and a 2nd power pedestal to run the RV.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
