I was wondering if anyone could help point me in the right direction to locate an interior door for my Keystone Montana 3850FL. The door is an 1' 1/4" and I spoke to the distributor that Keystone gave...
Same here just went to Lowes and bought one with the right measurements. Or close to that, I had to trim 1/2" from the bottom. Works great. You can order one with the exact measurements that you need. Be warned that you can only trim a little from the door since the only solid wood is at the edges on these flat panel doors.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
