pumpshep
Nov 02, 2014Explorer
INVERTER - help
So i have a inverter installed, and i have to run a extension cord to the tv to the inverter, is there any way to plug a cord from the inverter into the wall and have it power all the sockets?
John & Angela wrote:
Howdy again. Just want to be sure I understand. With ALL the breakers off the inverter is still loading down as soon as you plug the shore cord in.
Slightly off topic, how many batteries do you have.
SDurbak wrote:John & Angela wrote:
Did you remember to change your fridge to propane. Thats about 4 amps. How about the water heater electric element. Theres another 11 amps. Those two together would drag down a battery to the alarm voltage quick and probably kill the battery in about 20 minutes.
The fridge and water heater were both off. I even turned all the breakers off. So there should not have been anything pulling any power out of the battery. I'm really stumped.
ewarnerusa wrote:
Some inverters don't work. I'm not savvy enough to know why. The first inverter I bought was a Samlex MSW 800 watt and it acted the same as you describe. I later saw in the manual where it said to not use it to supply an ac panel. I suppose that is what I was essentially doing. Every other inverter I have owned has worked fine like this though.
Edit: I found my old thread asking about why it wasn't working. There might be some useful knowledge in there. It's funny reading my old comprehension level about this stuff and it was only a couple years ago!
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25837086.cfm
SDurbak wrote:
I tried this and it didn't work - what am I doing wrong? I bought a 1600 watt Whistler inverter, connected it to my battery, turned off the breaker to my converter, plugged shoreline power cord (30A) into an adapter, then plugged it into the outlet in the inverter, turned the inverter on, and within 2 seconds the inverter was alarming and shut itself off. Nothing in the camper is turned on, and I even tried it with all the breakers off. Same thing - alarm, then off. I plugged a crockpot into the inverter, and it worked fine, so I know the inverter is functioning. Any ideas?
I plug my shore power cable directly into the AC receptacle on my inverter. I shut off the breaker to my charge converter, as Mr. Wizard said. All sockets are live with AC power provided by the inverter.
