pumpshep's avatar
pumpshep
INVERTER - help
So i have a inverter installed, and i have to run a extension cord to the tv to the inverter, is there any way to plug a cord from the inverter into the wall and have it power all the sockets?
  • I plug my shore power cable directly into the AC receptacle on my inverter. I shut off the breaker to my charge converter, as Mr. Wizard said. All sockets are live with AC power provided by the inverter.
    Not into the wall, make an outlet for the shore cord to plug into with an adapter, unplug aka turn off your charge converter circuit , so it doesn't drain the battery
  • RoyB's avatar
    RoyB
    Explorer III
    I read the OP was asking if you could run a DOUBLE MALE 120VAC ILLEGAL hookup PLUG to PLUG extension cord and plug one MALE end into the Inverter and other MALE end into an existing 120VAC Receptacle which would back feed all the other 120VAC receptacles. This is where folks are calling this a dangerous and ILLEGAL procedure.
    Maybe I read it wrong...
    I use the standard extension cord here on my 600WATT PSW Inverter with one drop going to the home entertainment cent and the other drop going to the bedroom area where I have a few must have items ON all the time. I also have a 120VAC RECEPTACLE close to the Shore Power connections where I can plug the Shore Power Connection using an adapter to be powered by the INVERTER. This requires me however to flip a bunch of circuit breakers in the Power Distribution center before doing this since my INVERTER is not large enough to run the whole trailer.
    This is my OFF-ROAD POPUP floor plan showing how I would be configured using my INVERTERS...
    Roy Ken
    Moderator edit to re-size picture to forum limit of 640px maximum width.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    pianotuna wrote:
    Hi,
    Doing what you suggest is illegal and dangerous.
    Far better to run a cord to the shore power cord box and plug the shore power cord in. Be sure to turn off the converter, and set the fridge to propane.
    That's how I'm running my 300w inverter. Only use it for TVs and DVD. Easiest solution in my case.
  • If you installed the inverter close to the distribution panel you could use a small transfer switch to send power down one circuit.
    Otherwise NO on the suicide cord or dead man's cord.
  • Hi,
  • Easiest is run a line from the inverter to a dedicated outlet. Lable it and simply plug into the power you need
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 20, 2026
