Hi guys, I'm wanting to set up an inverter so I can run power off of my battery bank and solar. I had a 2000 / 4000 peak inverter that I had been using, but was tired of not having my outlets work...
The RV. I'm not sure, I've never used it on shore power. My friend has a large generator he uses for his. I could use it to check to make sure. But I'm assuming it works fine when plugged in.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 28, 2026
