Jhaw
Jun 03, 2017Explorer
Inverter help
Hi guys,    I'm wanting to set up an inverter so I can run power off of my battery bank and solar.  I had a 2000 / 4000 peak inverter that I had been using, but was tired of not having my outlets work...
time2roll wrote:
with just 2 batteries you need to get closer to 1000 watts max.
Not all inverters are made for the battery connected to the ground. Try removing the batteries from the RV to isolate.
Some inverters only provide half the rating to each outlet.
Ok and this is a good time to post the exact make and model of inverter(s).
