Hi guys, I'm wanting to set up an inverter so I can run power off of my battery bank and solar. I had a 2000 / 4000 peak inverter that I had been using, but was tired of not having my outlets work...
Get 2 battery disconnect switch. Wire them both to your battery bank AFTER the fuse. The output of one goes to your converter. The output of the other goes to your inverter. AT LEAST ONE SWITCH SHOULD ALWAYS BE OFF !
Now run an extension cord from the outlet of the inverter to your shore power inlet.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 28, 2026
