Hi guys, I'm wanting to set up an inverter so I can run power off of my battery bank and solar. I had a 2000 / 4000 peak inverter that I had been using, but was tired of not having my outlets work...
Whit your multimeter check for continuity in the trailer 120v panel between neutral and ground, when inverter and shore power is completely disconnected. There should be none. Only one bound neutral/ground which should be in the inverter.
But check the inverter troubleshoot section, to find what that blinking light means
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
