mapguy
Mar 19, 2016Explorer
DOITHARD wrote:
Ok so I will run MW with Genset...I'm planning on purchasing a PSW inverter and will install an add ATS. But where do I conect the ATS to, shore power at existing ATS?
Depends -whole panel or just inverter driven circuit/outlets. Easiest/seamless usage would be circuits/outlets. Check the link and investigate the pdf documents.
ST1500 psw at Best Converter
Search member smkettner posts for more install info, too. There are some smart guys here, too that will help if you outline your needs clearly and are reasonable. In your original "needs" the microwave just wasn't feasible.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
