DOITHARD
Mar 19, 2016Explorer
mapguy wrote:DOITHARD wrote:
Ok so I will run MW with Genset...I'm planning on purchasing a PSW inverter and will install an add ATS. But where do I conect the ATS to, shore power at existing ATS?
Depends -whole panel or just inverter driven circuit/outlets. Easiest/seamless usage would be circuits/outlets. Check the link and investigate the pdf documents.
ST1500 psw at Best Converter
Based on my restricted access to panel and easy of access to ATS, rather conect to existing ats and whole panel even though I will have limited wattage. With those givens, do I conect to shore or generator at ATS?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
