DOITHARD's avatar
DOITHARD
Inverter installation and automatic transfer switch
Need help!
2016 Lance 1172
I'm in the planning stages of purchasing and figuring out installation of a 2500 watts inverter.
I would like to install inverter 120v to camper 120v panel. However, camper has an existing automatic transfer switch...can the inverter be connect to the ATS and if yes, which feed shore or generator?
PS/ I realize that I'm restricted on amperage...I will only be using 120v for TVs, Directv receivers or charging phones and lap tops. Maybe once in a while a coffeemaker or MW.
Thank you in advance!
Carlos
  • 2000w is plenty. 300w is plenty for tv, direct, phone, laptops, dvd.
    Sine wave is best with MW and CM electronic controls.
    Best to have 4+ batteries to drive 2000w.
    Transfer switch can be installed in sequence with existing.
    Don't forget the LED lights and 200+ watts solar ;)
  • If you feed the panel directly, you'll have to remember to turn off the converter, set the fridge for propane vs. AC usage, turn off any electric water heater element, etc. I think it would be better to have a transfer switch just for selected circuits so that you have fewer things to remember.
    However, it would be possible to wire it as though it were a generator and use the transfer switch you have as it is. The inverter would have a time delay before the transfer switch switches, and there would be a minor load from the transfer switch relay coil. This gives the inverter priority over the shore power connection. (It would also be possible to reverse the connections and make the shore power have priority; I'm not sure there's much of an advantage to either setup.)
    For just TVs and chargers and such, you could get by with a much smaller inverter, and consequently lighter wiring to the batteries. If you have only one or two batteries, you'd be very limited in how much full power use you could get out of the big inverter. The coffee maker and microwave require a lot more power than the electronics.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,390 PostsLatest Activity: Sep 15, 2025
