MrWizard
Oct 01, 2017Moderator
K cup coffee maker the 'Hotel' model wait for the water to get hot, single cup of water reservoir
uses about 600w
the full size model uses 1100-1500w depending on brand and model
plugging the shore cord into the inverter is lot better much safer idea than a back feeding suicide cord
pulling 50 - 120 amps using these devices is best done with a larger battery bank,
don't expect your avg alternator to be able to handle this
the alternator will max out and not be able to do it
the batteries supply the majority of power the alternator adds a little extra
then recharges what was used from the batteries
uses about 600w
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
