MudChucker's avatar
MudChucker
Inverter installation
I currently have to t106's in the 5th. Im not totally averse to buying 2 more, I just dont want to if I dont need to.
The plan:
purchased 2 inverters, 500 watt pure sine, 1500 watt modified.
install the 500 watt and run 2 new outlets to TV area for sensitive gear.
install 1500 watt and run 2 outlets up to kitchen for microwave and coffee pot kettle etc.
the reason:
given the amount of waste energy through inversion, I figured that a 500 would be good enough for an LED TV and what ever, for about 2 hours max....
the 1500 would only be powered up if I wanted to make coffee or run the nuke or fill the air bed for 2 minutes...
we do carry a generator, Im shooting for convenience here for when we are not hooked up and boon docking or dry camping on the road.
I wouldnt plan to use the inverted power too long, like I said, maybe 2 hours of DVD movies or something. likely be something we did for about 5 day intervals before we plug in and fully charge up again, but will run the geny from time to time for an hour or so to cool the unit etc.
the question:
is 2 t105's enough ? will my 220 amp alternator be able to run enough amps through the light gauge wire in the 7 pin plug to replace some used amp hours through the day of driving ?
another question, has anyone wired up a switch or relay to swap the 110v from shore to inverter ? or is plugging in the norm ?
    the reason:
    Your wiring plan is questionable. What do you mean by 'run 2 outlets'? Some folks like me, find it much easier to supply the coach's breaker panel directly. That way there's no messy wiring to be done.
    As I'm sure you've read on this board, MWs don't do too well with MSW.
    I think you're going to struggle with just 2 batts for any heavy loads like the MW.
    Transfer switches are common.
    I'd get a big PSW and be done with it. 'Waste energy thru inversion' is a common gripe, but your approach seems to be a lot of work and expensive, relative to installing two more batteries, which you're going to need anyway.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
