MrWizard wrote:
The most technical but fool proof way is with a sub panel
Circuits you want to power get moved to the sub panel
A transfer switch goes between the sub panel and the main panel and the inverter
The transfer switch , changes between main panel or inverter
When using Shore lower or generator
Power flows main panel -ts -sub panel
When there is no external power shore or genset
Power flows inverter -ts -sub panel
This costs the most
But is totally automatic
________________________________________________
A manual switch inside is no different than using the shore cord plugged into the inverter
You have to remember to turn off certain items, run then on l.p.
Etc..
I like the idea of a sub panel. One question, when you say, "A transfer switch goes between the sub panel and the main panel and the inverter"... I'm not sure where you mean. Three things are listed and "between" suggests a location between 2 things. Ya, I know I'm being anal about detail. I'd really like to find a diagram of this.
