Chippo's avatar
Chippo
Iota convertor issues???? Long post...
Having electrical issues with a 2002 Jayco trailer with an oem Iota DLS45 convertor installed. Trailer was converted to 2 Trojan 6v batteries bout 5 yrs ago. Batteries are in good condition and show 12.3v stand alone and show 13.3 when 110v is supplied to trailer. I bring trailer home 2 days b4 goin on trips and plug trailer into shore power to get refer goin and so on. Today I plug into shore power and pop breaker in garage, which happens at times, due to overloading garage circuit. I plugged trailer into Honda 2000 geny and go inside trailer and do not have 110v inside. Go out to geny, turn off power savings and go back into trailer and now have 110v inside. Shortly thereafter 110v goes out in trailer and geny does not show any overloading and continues to run fine, never had any issues with geny. Ran geny for 2 hrs and plugged trailer into shore power and have 110v power inside trailer at this point. Is this an issue for a convertor that might be failing? All fuses/breakers in trailer are good. What might be giving us issues with incoming 110v in trailer, convertor or something else?
Thanks in advance....
  • Whether it makes sense or not, the battery is the first thing I'd check. 12.3 resting voltage is NOT a good battery. If it has no effect on your problem you still need a good battery.
    5 years is about time.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 11, 2026
