rhagfo's avatar
rhagfo
Explorer III
Oct 08, 2022
JC Refrigeration 12 volt compressor cooling unit
Well our cooling unit has failed, pretty sure no cooling on gas or electric. Noticed some dreaded yellow powder and a slight smell of ammonia.
So now looking at the JC Refrigeration 12 volt compressor cooling unit. I have the room for it, and it seems like it should work better then the absorption unit.
Are there any members that have real world experience with one of there units?
Our refer is a Dometic RM2862, the replacement unit runs $785, install is $0.00 as I will do myself.
We replaced the cooling unit 8/3/2018, so got just over four years out of a new unit. A new absorption unit runs $740, and a rebuilt is $450. That puts the cost on par with absorption unit.
We full Time and mostly park host, so almost always have power, we have two Interstate SRM-27 batteries in parallel, if without power.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Well unit installed and within 2 hours refer at 38 and freezer at 5 degrees. Nora bad DIY project, hardest part getting unit out of the box, very well packaged.
    X2 I also had difficulty getting the unit out of the box !!:E
    Housted
  • Your SRM 27 deep cycle batteries are NOT true deep cycle batteries but are RV/Marine batteries. They are compromise batteries. On a cold night they would probably NOT run the furnace and the refrigerator all night. The furnace blower is a high amp draw item.
    Richard
  • rhagfo's avatar
    rhagfo
    Explorer III
    Richard
    Furnace alone T-stat at 65, outside low 30’s ran all night, on a single five year old SRM 27. Now run two in parallel, I didn’t see an issue. That was for a nine day period, charged during the day.
  • OP, wondering if you have any updated info on usage? How many Amp Hours do you estimate the unit uses?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
