woodtrucker's avatar
woodtrucker
JC refrigeration AC or DC upgrade?
Just wondering if any of you could tell me whether I should buy the AC or DC conversion for my dometic rm2652.
We are on shore power almost always except for traveling. Would the truck charge battery enough to keep the 12VDC unit cooling while on the road?
If so, I'll go the 12V route.
Thanks,
Scott
  • rdhetrick wrote:
    My Dad just got one this week, it's not installed yet so no feedback on that, but we talked it through and he went with the 12v version on his coach.
    Reasoning was that when connected to shore power, the converter will provide the power, and while on the road or boondocking, he wouldn't need to run the inverter with it's losses. If by chance, the refer draws the batteries down faster than the alternator can recharge them (doubtful because I think it draws 7 or 8 Amps only when the compressor is running), he can always start up the generator.
    For anyone that is planning to be mobile, I don't see a compelling reason to go with the 120v version.
    That’s probably what I would recommend. No DC-AC conversion loss.
    Another option if the alternator can’t keep up would be a DC-DC charger. You could probably install a small (charging amps) DC charger without a wiring upgrade, and your house batteries would charge better too.
  • I vote 12. If you do camp without power or there is a power outage, it will run off your batteries...for a while at least.
  • enblethen wrote:
    Why not just run on propane?
    Because the conversion isn't an absorption refer - it's a compressor similar to a household refer.
  • My Dad just got one this week, it's not installed yet so no feedback on that, but we talked it through and he went with the 12v version on his coach.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 29, 2025
