bob_nestor
Oct 09, 2016Explorer III
westernrvparkowner wrote:
Just to recap. Washer broke, out of warranty, decided better value to replace than repair. OK, sounds like a decision people make every single day. What I don't understand is where the value is in getting a 220 volt washer? That would render it useless in almost every residential application without some rewiring and I don't believe your solution meets NEC code. Also, I don't believe it would be a practical choice for an RV since the washer would be inoperative when connected to anything other than properly phased 50 AMP Pedestals. But hey, thanks for the post, otherwise it's been a slow day at the forums.
The washer plugs into the dryer so both can run off a single 220 outlet found in most homes and it doesn't violate NEC code. (All of the manufacturers of compact units do this.) But if you'd prefer 110v compact washer/dryers look at the Electrolux/Frigidare line. Also, all the compact washer dryers I've looked at are ventless, making them a good choice for a small space not originally designed for external venting.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
