FirstTracks
Dec 13, 2017Explorer
memtb wrote:
I don’t think that diluted (once you start filling the tanks) will help. I see your only option as....heat tape and insulate the lines and the dump valves. And “Be Certain” that your dump valves “do not” leak by. Even just a few inches of solid ice between the dump valve and the end cap... can be a real pain! Been there - done that!
Great tip on the leak! And thank you for the reinforcement of my suspicion that dilution would likely keep the antifreeze from doing what it must. The heat tape/insulation is the route we took.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
