pianotuna
Dec 13, 2017Nomad III
Next time try a radiant heater. It doesn't warm the air, it warms the object it is pointed at. It takes a while but with care it will thaw the frozen area. Please monitor carefully--or you might find you have a serious fire problem.
SidecarFlip wrote:
I've experienced the frozen up dump valves before and there is no easy way to unthaw, or should I say a no mess way to unthaw. Heat guns work but when it 'breaks loose' it's a mess.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
