memtb
Dec 13, 2017Explorer
pianotuna wrote:
If you listen to his video you will find he is using heat tape that is 3 watts per foot and 3 feet long. That works out to 9 watts or 30 btu's. I don't think that is enough. For comparison, a regular candle does about 80 watts or 278 btu's.memtb wrote:
pianotuna, No disrespect intended, but.....we lived in a 5er for two winters, seeing numerous -20 to -30 F ( probably some a couple colder), and kept our water on to our camper. We were using a six foot frost-free faucet ( heat taped/insulated to the six foot depth) and the water supply hose to camper was heat taped/ insulated ( your typical foam pipe insulation.
My apologies....I should’ve watched the video first. I concur... probably “not” enough btu. I must have had “high horsepower” heat tape! :) But, time and a cold day or two will tell.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
