Time for a new top and sink. Any thoughts on removal of the existing countertop? Will it come out with damage to the drawer fronts and cabinet walls? Is it simply screwed in from below?
I've seen a granit type material that is thinner than normal and made to be glued over laminate. The edge is attached to you don't see any of the old top unless you are looking up from the floor.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
