etrippe's avatar
etrippe
kitchen countertop removal
Time for a new top and sink. Any thoughts on removal of the existing countertop? Will it come out with damage to the drawer fronts and cabinet walls? Is it simply screwed in from below?
  • This^^, but my experience says the counter from manufacturers is usually cheaper particle board verses the better MDF. Either way removal is the same. I installed counters for years and some got glued down but most were just screwed down, but after the laminate had been pre-applied. I wouldn't be surprised though if an RV top was Glued and Screwed.
    Edit: if glued, a crowbar or wrecking bar can pry up the countertop from the cabinet but be sure to pry overtop of the vertical frame pieces and not on the cross bars that go over drawers or cabinet openings. They could be popped out of alignment. Best would also be to do this from inside the cabinet as to not ruin the outer finish.
    Good luck.
  • Have no idea how they build those units, but laminate is normally glued onto a substrate like MDF. Then the MDF is typically screwed into from below. I doubt the substrate would be glued down. Just look from underneath to see if there's screws. The laminate/substrate counter top will come out together as an assembly.
    There should be caulking all around the countertop perimeter which will need to be cut to break the seal, then completely removed before installing new caulking. (If it's silicone, silicone will not adhere to cured silicone.)
    When it comes to RVs, not much is straight, plumb, level or square as it should be. You should carefully check before cutting a new counter top. A template may help. If there is a wall at left and right hand sides of the top, you do NOT want to cut wrong or too short... The back wall may not be straight either - so check with a straightedge.
    Remove any drawers. It will probably help to remove cabinet doors (by undoing screws in hinges). If a range in there too, you should pull that out - but do NOT forget to reconnect the propane properly.
    Are you getting a new top pre-cut to size or buying an over-sized piece and trimming it?
  • Artum Snowbird wrote:
    I would strongly suggest you contact Georgie Boy to see what they say. I am sure there is as many tie downs and screwed/glued combinations as the mind can imagine.
    GB was bought by Coachman and I have sent them an email. Hopefully somebody is still around that remembers. Thanks
  • donn0128 wrote:
    What type is it?
    Typically if it is laminant the sub straight is screwed or stapled down, laminant is then glued on.
    If it is solid surface it will be glued down with silicone.
    When I have removed both of my counter tops, i simply set my circular saw to make shallow cuts, cut the counter top, and pryed them up and carried them out in pieces. No damage.
    The existing is laminate and I was hoping you wouldn't say "laminate is then glued on". But that is a good suggestion to remove it by cutting shallow cuts. Thanks
  • I would strongly suggest you contact Georgie Boy to see what they say. I am sure there is as many tie downs and screwed/glued combinations as the mind can imagine.
  • What type is it?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,389 PostsLatest Activity: Sep 06, 2025
