Dutch_12078
Oct 08, 2017Explorer III
Better or worse what? Pressure? Flow rate? The answer to both though, is "No." The limitation is the inlet bore on the pump as well as the internal pump "plumbing" where the water passes through the diaphragm ports and check valves. The only practical cure for that is a pump with a higher pressure/flow rate capacity.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
