GordonThree
Oct 08, 2017Explorer
When I plumbed my aux water tank to a 4.5 gpm 65 psi marine pump, I originally used a 1/2" right angle hose bib. It didn't supply enough water to the pump and there was considerable cavitation on the impeller. I upgraded to a straight 3/4" boiler drain valve and that solved the issue and improved the discharge.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
