westend
Oct 08, 2017Explorer
No, it won't change delivery rate on the pump output. If you have a loss of pressure, elevate the aux. storage tank. The small diaphragm pumps used in most RV's do not have a big pump head lift. You could also put a bigger pump on the aux tank and use that through the utility fitting input.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
